L98 or LB9?
Old Mar 25, 2003 | 08:21 PM
prockbp's Avatar
Car: 1989 IROC-Z
Engine: 1992 TPI 350
Transmission: 1989 T5
Axle/Gears: 1992 10 Bolt Rear w/ 3.42 gearing
L98 or LB9?
i recently bought an '89 IROC..... it's a 5speed, so i know it was originally equiped with an LB9...
but... i suspect that one of the previous owners may have swapped in an L98.... is there a casting number or something that i can look for to find out for sure?
or is there another way to tell which engine it has?
thx for the help guys
Old Mar 25, 2003 | 09:05 PM
Vader's Avatar
Ther eis a seven- or eight-digit casting number on the rear ledge of the block casting, near the distributor. Get the number and check the data at www.mortec.com
Old Mar 26, 2003 | 11:27 PM
prockbp's Avatar
Car: 1989 IROC-Z
cool.. thx
Old Mar 27, 2003 | 11:03 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
It may even say what engine it is by the casting number. I have a block in my basement that along with the casting number says GM 5.7L.
Old Mar 27, 2003 | 01:29 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Everyone hopes that the 305 car will turn out to be a 350. But it will not happen 99 44/100% of the time. One sure way is how does it drive.
Old Mar 27, 2003 | 07:17 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
what makes u think its a 350
Old Mar 27, 2003 | 09:25 PM
jamr0d's Avatar
i'm in the same situation.. my vin says l89 but i'm just curious ... i found a number on the front drivers side of my block.. it's 638 can that identify my engine??
Old Mar 28, 2003 | 02:27 PM
Drakar's Avatar
14093638...350...87-95...2 or 4...Roller or flat tappet cam
That is what www.mortec.com found for the last 3 digits that you gave, so it does show the correct block for the year.
Old Mar 28, 2003 | 04:32 PM
92RSZ's Avatar
Car: 91 Z-28
Engine: 420 sbc
Axle/Gears: 12 bolt/4.10 gears
the easiest way is to do what viprklr says. Get a flashlight and dig down past the wire harness on the drivers side of the block just in front of the transmission bellhousing. It will either have a 5.0 or a 5.7 on it. You can check numbers if you want, but that is the easiest/fastest way.
Old Mar 29, 2003 | 02:21 PM
jamr0d's Avatar
thanks for the help
Old Mar 30, 2003 | 12:58 PM
prockbp's Avatar
Car: 1989 IROC-Z
well, i'm not a pipedreamer.. i can afford a new engine... but why buy one when i allready have one to work on?
how should i know the difference between the way the torque feels with a 5.0 vs. a 5.7....
it drives good, gobs of torque but not much top end to speak of... i also have a 2000 LS1 Z28, so that's my only basis of comparison
the tacometer is wayyyy off so i can't tell you where the power is in the RPM range... the tac says that it idles at like 2500, and the needle is out of range pretty much anytime i get on it
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Tarizza
Sep 24, 2015 12:57 PM
