internal coil to an external coil
Old Apr 1, 2003 | 10:35 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i have an internal coiled hei and i want to convert it to an external. can i do this? is it just a cap or what is all entailed in it?
Old Apr 1, 2003 | 12:16 PM
Vader's Avatar
Sparty,
I believe you'll have to change the connector to the distributor cap, or adapt the primary connections to the external coil. Obviously, the cap and rotor will have to be changed, unless you want to install the MSD modifird HEI dust cover/adapter (P/N 8401). They're about $28 and complete the HV circuit for a separate coil to a standard HEI distributor.
http://www.northernautoparts.com/Pro...ctModelId=5317
http://store.summitracing.com/partdetail.asp?part=9033
Old Apr 1, 2003 | 12:30 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
so its possible to go from int. coil to ext. coil but is that true vise versa?? I would like to put a large cap dist in my maro that is a 92 Would this be possible with just splicing?
Old Apr 1, 2003 | 03:53 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
hey thanks vader. i was looking for something like that. are there any pros and cons to doing this. i was looking for something a little more attractive to my engine that the funky looking internal coil cap as to why i was wanting to switch to external.
Old Apr 1, 2003 | 04:13 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
cons: your wire terminals will be closer and you will have more of a chance of ionazation and crossfire inside the cap, Large cap is better performance but the small cap ext. coil does look better.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
mfp189
Sep 27, 2015 09:25 AM
