assistance needed
Old Apr 1, 2003 | 11:08 AM
Awesome89's Avatar
assistance needed
my temperature gauge is not working at all, i have a new sensor, i thought that would be a good place to start, i was wondering though, which side of the block has the sensor that leads to the gauge and which side has the sensor that leads to the computer? i believe the one i need is on the passenger side, is this correct?
Old Apr 1, 2003 | 11:38 AM
Vader's Avatar
Awesome,
What engine do you have? There may actually be three coolant temperature sensors, plus an intake air temperature sensor. the sensor for the dash gauge is completely separate from the sensor used to signal the ECM, and separate still from any auxilliary sensor for a secondary cooling fan. The location of the sensors depends on the type of engine you have.
Old Apr 1, 2003 | 11:40 AM
Awesome89's Avatar
i have a 350 bore .030 over, it's crate, 88-newer
Old Apr 1, 2003 | 11:50 AM
rezinn's Avatar
Nope. Should have a single wire connector in the drivers side head for the guage sender. Follow the wire back into the harness and make sure its in tact. The computer sensor is in the intake manifold. The fan switch Vader mentioned is in the passenger side head.
IROCZ1989
Jan 24, 2016 03:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
