hesitation
Old Apr 2, 2003 | 09:27 AM
rayth's Avatar
hesitation
I am in need of an opinion. I just bought an 87 GTA and I have noticed that if I give it WOT off the line it will hesitate for a bit, actually as if I were just taking off normally. Then after a few seconds it will pick up and get after it like it should. Also, on the highway I can be cruising along in overdrive at about 75 or 80 and if I try to give it more gas, say half pedal, it will hesitate and borderline surge. I have a few ideas of what could be causing all this, but I thought I would see what you guys thought before I start doing anything. Thanks for your time.
Old Apr 2, 2003 | 10:28 AM
v8unleashed's Avatar
i had this problem, and about 12 sensors and $200 later, i decided to change the spark plugs. #8 had apparently never been changed, and that fixed it. it helps when all cylinders are firing. since you just bought it, try doing a tune up.
Old Apr 2, 2003 | 01:37 PM
rayth's Avatar
yeah, I planned on changing the plugs and wires, cap and rotor, and putting a new fuel filter in it. It probably needs all those things anyway. I was just curious if someone, like yourself, had run into the same problem and knew something I didnt. thanks for the info though.
Fanatic1074
Oct 3, 2022 05:57 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
