No spark
Old Apr 3, 2003 | 02:17 PM
Tonyrodz's Avatar
Transmission: auto
No spark
I'm starting to play w/my T/A again--after sitting for a long time--it just won't start! It has fuel, inj.'s are firing but no spark! I took a known good coil from my Monte and swapped over-thinking that was the problem--still have no spark! all fuses look ok too.
I unplugged the passkey just for the hell of it-only the security light went out but still cranked--plugged it back on-security light was on(don't remember if it stayed on while cranking)and still won't start!! Car started and ran fine before I swapped my dash out(car is an 86 w/89 drivetrain and 92 dash).
I'm at a loss!! any help would be greatly appreciated!!
Old Apr 3, 2003 | 02:46 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Are you getting spark at the other end of the coil wire? Have you replaced the ignition module? I don't think the ignition module would cause a no start situation, but it's worth a shot.
Old Apr 3, 2003 | 04:00 PM
Tonyrodz's Avatar
Transmission: auto
How could I tell if I'm getting spark at the other end of the coil wire? I swapped back the coils, and the other coil started the Monte right up. Now my security light is staying on so I'm assuming it's the vats--maybe.
Also--the ign. module--the one in the distributor? If that's it I haven't replaced it yet.
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
