Accell Header Plugs
Old Apr 2, 2003 | 09:55 PM
1982Camaro383's Avatar
Accell Header Plugs
I have a 1982 Camaro with a modified 350, I was debating on trying the accell header plugs. Has anyone used them before are they any good. I am currently using NGK. Any suggestions would be great.
Thanks,
Justin
1982 Camaro
Old Apr 3, 2003 | 05:47 AM
ede's Avatar
ede
i've used them, only because they were shorter, other than length i'd stick with regular old ACs.
Old Apr 3, 2003 | 12:57 PM
gtabadboy's Avatar
I used them too but came to find out some reg plugs were the same length. Also an important fact that I ignored is that the plugs that accel makes do not go far into the heads. The part that screws in was too short for my Dart Pro 1s. Make sure they are the same length.
Old Apr 3, 2003 | 04:33 PM
I have GM Performance Parts Drilled and Tapped Vortec Heads, I have to use long threads because they sit back in the compustion chamber, shorty threads don't come close to the chamber.
Justin
1982 Camaro
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
tazs2000
Jul 15, 2017 08:44 AM
evilstuie
Feb 28, 2016 03:33 PM
tricky1
Aug 23, 2015 01:17 PM
