hydrualic to roller?
Old Apr 4, 2003 | 09:13 AM
SlowMaro's Avatar
what do i have to do to convert a hydrualic to roller?? put in a roller cam and roller lifters?? anything else? or is it even possible....
Old Apr 4, 2003 | 09:56 AM
kevinc's Avatar
Car: 1982 Z28
Your '92 305, if it's the factory engine, is already (hydraulic) roller so need some clarification on which one of the following is true:
1.) you mean solid roller
2.) you're talking about another engine (specify what it is)
3.) you're an idiot
Let us know which path you're on.
Old Apr 4, 2003 | 09:58 AM
SlowMaro's Avatar
--smack-- ....B.) an 86 350......
Old Apr 4, 2003 | 10:07 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
QUite easy.
You can do the same thing all the rest of us had been doing for all those decades that we've been building roller motors, before the factory "invented" their bizarre twisted approach to rollers, and re-invented the wheel but came out with a triangle instead.
You use what are now referred to as "retrofit" roller lifters, which are joined together in pairs by cylinder with a link to prevent them from turning; a roller cam, of the "retrofit" variety; and a cam button, which is a little thrust roller bearing or plastic button, to keep the cam from walking out the front ot the block. Push rod length is almost always different from the ones for flat tappets, usually about .400" shorter. No machine work, no special blocks, no modifications to anything at all, just slap it in and go. It's just too easy. I fail to understand why the factory took such an expensive turn down a dirt road to do what they did, and came up with something so inferior and full of problems and expensive in that it required new block castings and machine processes.
Old Apr 4, 2003 | 10:10 AM
kevinc's Avatar
Car: 1982 Z28
Good deal!
You thinking hydraulic roller, or solid roller? Pretty close cost involved either way, the solid will involve periodic lash setting.
If hydraulic roller, look into retrofit kits from Crane and Comp Cams for an idea of the parts and cost. Little blurb from Comp below:
http://www.compcams.com/catalog/044.html
http://www.compcams.com/catalog/258.html
Old Apr 4, 2003 | 02:18 PM
Drakar's Avatar
What are the benefits of roller over Flat tappet?
Performance?
Wear factor?
can't be price cause flat tap is what 50 years old or so?
Old Apr 4, 2003 | 02:45 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Try that.
http://www.chevyhiperformance.com/te...258/index.html
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
