Noy Third Gen related but need help
Old Apr 6, 2003 | 05:32 PM
EFF26's Avatar
Car: 1991 firebird
Engine: lo3 305 TBI
my mother has a 94 nissan quest mini-van and the fuel guage has suddenly stopped working . If any one can help me I would really appreciate it aalot so I do not have to take it to the dealer .
thanks eff26
Old Apr 7, 2003 | 05:50 AM
ede's Avatar
ede
look for a bad connection with either power or ground wire
Old Apr 7, 2003 | 08:36 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Very common problem with nissan's. The most common prolem found is a break in the guage pod itself so that would mean replacing the cluster. Check the fuses and the ground wire from the fuel sender, nissan uses a 18 guage wire to frame. If all that checks out you can use an ohm meter as a make shift fuel gauge to test the sender itself.
Old Apr 7, 2003 | 11:34 AM
EFF26's Avatar
Car: 1991 firebird
Engine: lo3 305 TBI
thanks alot I will try these things out .
mddaniel
Sep 8, 2015 05:16 PM
JHX
Aug 29, 2015 02:30 PM
Thirdgen89GTA
Aug 25, 2015 06:40 PM
86IROC112
Aug 21, 2015 07:20 PM
redmaroz
Aug 16, 2015 11:40 PM
