valve-tap? HELP!!!
Old Apr 8, 2003 | 01:54 PM
rxbxfx0220's Avatar
valve-tap? HELP!!!
For the past two weeks or so my engine has been clanking under acceleration and a tad during cruising. My radiator was busted for a couple months, so I had to fill it before I went anywhere. I just put in a new one, but I think the damage has already been done. it definitely sounds like valvetap... i checked the oil and it was fine, and i thought maybe i just got a cruddy tank of gas, but i've filled it up a few times since and it's still doing it. I use the regular unleaded, just like I always have so it's not because of gas or low on oil... Anyone have a suggesstion, I'd rather fix it now then have to spend $500 on heads later. Thanks, Steve. (oh yeah, the engine is a 305 carbed with auto trans, just in case that makes a difference)
Old Apr 8, 2003 | 01:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's not a valve, or anything to do with valves. Sounds to me like you might have spark knock. Just for the fun of it, try a little higher-octane gas, and see if it clears up (or at least if it helps).
It also might just be an exhaust leak, under the hood, very close to the engine; like where the manifolds bolt to the heads. You might want to just tighten all those bolts.
Old Apr 8, 2003 | 05:22 PM
rxbxfx0220's Avatar
I'll try some higher octane gas, and this Sat. I'll play around with the manifolds a bit and see what's up. Thanks.
