temp Q's for anyone running aluminum heads
Old Jul 23, 2000 | 01:04 AM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
I was wondering what kind of changes in the operating temps people had when they changed to aluminum heads what your temps were with IRON heads and now with the alum heads. I have a set of alum heads but and fighting a heating (or I should say cooling) problem and dont want to put a new set of alum's on and warp them. Also will running lean increase the heat? I keep getting a code 13 that comes and goes . Thanks guys
'87 Monte Carlo SS,with '89 IROC 350,700 trans, blew up 3.73 posi stuck with crappy 2.73's neeed gears! hooker headers, flow's 2 1/2" exhaust true dualls
Old Jul 23, 2000 | 11:34 AM
Box of Rocks's Avatar
SS,
I'd look for a 20* reduction, all else being equal. And yes, lean = heat, bigtime. Richen the mixture a tad and you'll see the temp come down.
Good luck.
BOR
Old Jul 23, 2000 | 11:40 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
As for cooling with Al heads, run ONLY deionized water with a healthy 50/50 mix of coolant, otherwise your heads will start to corrode eventually. Oh and code 13 is the O2 sensor, time for a new one. HTH
George P. Lara
1984 Z28 High Output
Proud Member of SCFB
V6 T5 For Sale
Old Jul 23, 2000 | 11:55 AM
monte-ss's Avatar
thanks guys I guess Ill have to stick my AFPR on here real soon
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Reddeath210
Oct 6, 2015 08:20 AM
TheExaminer
Aug 26, 2015 04:59 PM
z28addict8490
Aug 7, 2015 08:48 PM
