need help with TV cable and wiring....
Old Jul 22, 2000 | 04:24 PM
phrac's Avatar
Alright, my first question is how to adjust the tv cable. Do you do the adjustments on the carb or do you do them to the actual cable?
Second question: I've seen a lot of talk about ripping out the wiring harnesses for the computer. Right now I am running without the computer, yet i still use wires for the HEI distributor (the tach and battery connections) and the wire to the temp sensor. Now if i pull out the wiring harness, those wires will be missing so how do you go about this?
Old Jul 23, 2000 | 12:12 PM
phrac's Avatar
i figured out the tv cable, but what about the wiring? anyone? btt
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
