Engle Cam Identification & Information
Old Jul 23, 2000 | 02:19 AM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
Earlier a few months ago, assisting MeanYellowZ in engine work and cam replacement, he was discussing throwing away a cam he had. I quickly jumped on the VERY LOW MILE cam and later we discovered the cam wasn't the problem, but his rockers/timing/carb settings were his problem. My point to this post is to identify and get the specifications from either a private party, or a link to the internet site (if any exists) for Engle Cams.
The cam is stamped on the back side "Engle - EP 20 HYD 10 C"
Any help would obviously be appriciated.
Duffster (age 31)
BEAT DOWN HARD'88 Camaro SC
Loose rod havin 305 TBI, 1st and 2nd gear only 700 R4 Auto,
(but not for long--newly acquired 700R4),
'84 Z-28 Nose clip wearin', '84 Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 (1),
245/60-16 Bridgestone CompTA's(on rear),
235/60-16 Pirelli P600 w/a curb check or 3(1),
REAR HATCH MASTER OF ALL!!!
...and a new ECM (which will be removed for a Q-Jet)
Duffster_Camaro@HOTMAIL.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, also part of the non-existent Iowa crew.
Old Jul 23, 2000 | 12:13 PM
Vader's Avatar
Duff,
Nice to hear from you again. A couple of quick checks with a 2" mic or caliper should give you the final lift numbers. If you have some 'V' blocks and an indicator, you should also be able to plot the curve to determine duration and ramp as well. The killer is going to be the initial timing. I've never had much luck trying to key off the dowel to find really accurate timing numbers. Variations in production tolerances don't help either. My "peanut" cam has about 0.004" more lift than it's supposed to, for example (after adjusting for lifter compression).
Good luck finding "Engle".
Later,
Vader
"Some Body...Someone"
Jorlain
Oct 8, 2015 01:57 AM
Strick1
Sep 4, 2015 07:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
