Simple timing question
Old Apr 12, 2003 | 09:46 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
If you are at TDC for the #1 cylinder and you rotate the crank clockwise 360º what cylinder will be at it's firing position?
Also, before I dropped my distibutor in I had the #6 cylinder at it's compression stroke (I checked when I had the heads off). When I dropped the distributor back in couldn't I just place the wires so that the rotor is between the #6 & #5 plug wires and continue clockwise from there (7,2,1,8,4,3)? This should get me in the ballpark right? Is this an extremely easier way than rotating the crank for #1 TDC (My socket broke) or am I missing something?
Old Apr 12, 2003 | 10:29 AM
87Formula4bbl's Avatar
Car: '87 Formula
You should be at number 6. Sounds like it should work. I know what you mean about rotating the crank tho, PITA. You could just tap it until you get it close and then turn it the rest of the way (small amount) with your hands if your strong enough, that worked for me and my dad.
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
camaroken83
Aug 10, 2015 11:35 AM
