What timing and Fuel pressure should i be running with this setup ?
Old Apr 12, 2003 | 11:51 AM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
Trying to tune my car but having alot of trouble with it in drive especially down on the lower end, what timing and fuel pressure would you guys run with this setup, assuming ive set all the sensors correctly.
355 .030 over 9.1 compression
AFR 195 heads
Comp Camps roller grind for blower specs:
276 intake, 290 exhaust
510 intake with 1.5 rocker
510 exhaust with 1.5 rocker
Crane aluminum rockers 1.6 ratio
TRW blower pistons, Total seal rings, Eagle Sir Rods 5.7, GM 1053 steel crank, Moroso 6 qt pan, High volume pump and pickup.
Edelbrock aluminum water pump, Holley
StealthRam, 32# accel injectors
58 MM BBK throttle body
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
bryan623
Mar 22, 2021 06:43 PM
86IROC112
Aug 17, 2015 02:00 PM
Kaweh
Aug 9, 2015 02:54 PM
