Broken Spring Performance
Old Apr 11, 2003 | 08:52 PM
87Formula4bbl's Avatar
Car: '87 Formula
Quick question:
What kind of performance loss would you see from a broken or weak valve spring? Would it be drastic?
Also, could this possibly cause a loud knocking sound at higher RPM's, but not at idle??
Any input appreciated. Thanks!
-Ben
Old Apr 12, 2003 | 06:30 AM
ede's Avatar
ede
you'd have a dead hole, you'd know it
Old Apr 12, 2003 | 09:32 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, it would be drastic. It would manifest itself in other ways besides knocking noises.
If you have what sounds like a RPM-dependent knock that occurs at valve train speed as opposed to crank speed which is double the valve train speed, then it's probably a rolled / rolling cam lobe.
Old Apr 12, 2003 | 10:22 AM
Car: '87 Formula
I'll check today to see if it is RPM dependent or if its the same frequency as the valvetrain. Hopefully this will give me a little better idea of the problem.
Old Apr 12, 2003 | 11:52 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Also, if you hook a vacuum gauge up to the engine a broken valve spring will make the needle bounce up and down rapidly.
...been reading my ASE A1 study guides too much!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
snakeshooter
Sep 7, 2015 11:15 AM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
