Bottom end going to be a problem?
Old Apr 12, 2003 | 03:46 PM
Kiwi-85IROC's Avatar
G'day...I've just put my car in the shop to have some World S/R heads and a Comp cams XE262 fitted, ported Plenum and port matched intake and AFPR added. It already has Hooker headers and free flow 3 inch single exhaust
One of my mates said yu might get bottom end problems due to new heads going on and everything being re tightened.
Question is: On a 305 TPI is this an issue with 60k on the clock? and or at what stage HP wise is the bottom end on a 305 likely to give problems?
The car is due to get a 100-150 Shot TPI NOS kit added a couple of weeks after other mods are done and I've been to the track to update my times.
Old Apr 12, 2003 | 08:36 PM
ede's Avatar
ede
i wouldn't worry about it too much untill you give it a shot of juice. when you start running power adders you'd want forged parts, like pistons and crank.
Old Apr 13, 2003 | 02:45 AM
Ede:
Question:The After market chip which I have installed gives me aggressive timing. Will a timing retard box that MSD makes, defeat the advance the chip is trying to acheive when I set the timing to retard on the MSD box for nitrous runs?
Old Apr 13, 2003 | 08:24 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
As long as it has TPI on it, that will protect the bottom end from even nominal stress, and guarantee a long and easy life for it.
60,000 miles is nearly brand-new for a small block Chevy that has been properly cared for. I have a car with a 305 that we bought when it had 60,000 miles on it; it now has 345,000 on it, and the intake manifold hasn't been off yet. The timing cover has; but not the intake or heads.
Old Apr 14, 2003 | 01:17 AM
Is it necessary to retard the timing using only a 100 shot of NOS or will the current knock sensor do the job?
theshackle
Mar 5, 2017 06:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86IROC112
Aug 21, 2015 07:20 PM
