glug glug black smoke
Old Apr 12, 2003 | 07:38 PM
SlowMaro's Avatar
ok...car will run FINE...shut it off....and crank it again...glug glug....black smoke....pop the hood, ..turn the dist....it stops....i replaced the ignition module about 3 weeks ago....coud it be that it was faulty from the start and is slowly dying now?? ....i checked my plugs, ...they are fine, ..wires...brand spankin new... coil , cap, rotor...all new....could the lt1 cam be causing this?? ...1 inch spacer for the tbi unit doing it?? all the engine grounds are fine....i seriously have no idea here...HELP!!! please!!!!
Old Apr 12, 2003 | 09:23 PM
kevinc's Avatar
Car: 1982 Z28
Whip out your timing light, disconnect the EST, and report back what your spark advance is.
Old Apr 12, 2003 | 10:12 PM
SlowMaro's Avatar
ten four...--off to rent a timing light-- even though i dunno how to use one *sad huh* heh....i can hear the roar of laughter
gta892000
Aug 11, 2019 11:16 AM
Stryker412
Sep 20, 2015 06:59 PM
m00n420
Sep 11, 2015 02:39 PM
Accerrito22
Sep 5, 2015 09:34 PM
Out-Cast
Canadian Region
Sep 4, 2015 10:13 AM
