Is the S.O.B to big
Old Jul 23, 2000 | 11:48 AM
Jeff87IROCZ's Avatar
Is the S.O.B to big
I just would like to know if I install 17x10 inch wheels on my 87 Iroc, will I have any problems with the tire rubbing in turns or over bumps.
Old Jul 23, 2000 | 04:29 PM
Chad91Rs's Avatar
It depends on what tire you plan on running.
For a 10" rim you'll need at least a 5.5" offset in the rear.
You might be able to squeeze a 285/40/17 inside the wheel well but it'll be close.
If your car is lowered you might run into the outer lip contacting the tread on hard dips.
I have 17x11" rims in the rear with 315/35/17's and 6" offset that work with a small amount of rubbing.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
dusterbd
Sep 29, 2015 08:40 AM
