Switched carb spacers, now car wont start...
Old Apr 13, 2003 | 04:04 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Hey.. just switched from a 1 inch spacer to a 2 inch spacer and now the damn thing wont start.. got it to start for a few seconds but it just stalled out and wont stay running.. got it pretty well flooded now.. anyway why wont it start? i had the carb sitting on its side for a while.. did i **** up the float level? if so how do i reset it? its a holley 650 dp... any ideas are welcomed..
Old Apr 13, 2003 | 08:18 PM
SlowMaro's Avatar
try tapping the sides of it with a hammer....might loosen the float....make sure your air/fuel mixture is ok......
Old Apr 13, 2003 | 08:21 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
you also have to remember that adding the spacer will increase your airflow, your probably running a bit lean.
Old Apr 13, 2003 | 08:23 PM
SlowMaro's Avatar
better than my problem, ....id crank my car, run fine, shut it off, crank it again, ..glug glug ran like ***.....so i took the dist out, cleaned everything , hooked VERYTHING back up correctly., now it wont start at ALL.....and everything is fine....dist in right, plugs in right order ,...etc etc....
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
kah992
Aug 19, 2015 02:55 PM
86IROC112
Aug 17, 2015 02:00 PM
matthew911
Aug 12, 2015 09:38 AM
