What's the gear ratio by axle code?
Old Jul 22, 2000 | 05:44 PM
87Transam's Avatar
I know this question belongs in the V6 board and I have posted there but maybe someone here can quickly help me. My friend would like to know what ratio he has in his 1986 2.8 Camaro 5-speed. Unfortunately the build sheet(rpo) is missing and the only thing he could find is the code stamped on the housing.
The code is 2HL and we know for sure it is an open differential. Thanks very much.
Old Jul 22, 2000 | 06:06 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
2HL = 3.42 ratio. Nothing mentioned about being a posi or locking diff. Jack up one wheel and see if it turns.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
Best ET on a time slip: 11.857
Best corrected ET: 11.233
Best MPH on a time slip: 117.87
Best corrected MPH: 125.46
Best 60 foot: 1.662
Racing @ 3500 feet plus density altitude!
Member of the Calgary Drag Racing Association
[This message has been edited by Stephen 87 IROC (edited July 22, 2000).]
Old Jul 23, 2000 | 05:53 PM
87Transam's Avatar
Thanks Stephen
Old Jul 23, 2000 | 06:27 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Here are all the axle codes for 1986.
http://216.35.120.23/discussion.cgi?...20&article=122
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines,
5-point racing harness, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Speed-sensitive steering conversion, underdrive pulleys, Crane Hi-6 & more. 1.05g skidpad verified.
Old Apr 22, 2003 | 12:12 PM
fbodyking's Avatar
Has this been confirmed because I was looking for the same info just the other day.
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
Regal105
Aug 23, 2015 03:45 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
