Bloody choke, BAH!!!
Old Jul 23, 2000 | 06:14 PM
Hype's Avatar
Welp, for some reason or another my carb doesn't want to kick out of it's fast idle for like 20mins of running. After 20mins, I have to shut it off, then restart it to grab that healthy 750RPM I love with my lumpy cam.
I'm quite the novice when it comes to carb tinkering, or actually pretty much anything in general. =P Sitting at intersections with your car revving at like 1200RPM I find annoying considering it's a fairly loud engine. It used to kick down immediately by giving it a little gas, but no more.
What needs to be adjusted here? I have the electronic Q-Jet, and it's an 83 305LG4.
While I'm here, what can be done to improve shifting? I have the T-5 transmission (200,000km on it too) and it seems a little sloppy when I wanna really get on it and rip through the gears. I really have to engage the clutch quite consciously, wait a good .5 sec before ripping it into second or else it'll grind like a bastard. I guess the 1-2 shift is the only bitch, and likewise the 3-2 downshift.
Thanks guys.
Old Jul 23, 2000 | 08:36 PM
Hype's Avatar
BTTT
Old Jul 23, 2000 | 08:58 PM
JP84ZROC
Guest
Posts: n/a
Two things: first,check for sticking choke blades, second check the throttle kicker in front of the throttle lever on the carb for proper operation(there is a relay associated with the kicker located on the driverside fire-wall.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
apie2546
Sep 24, 2015 12:27 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
