I Cant believe this happened... HELP!!!!
Subscribe
Jul 21, 2000 | 11:30 PM
Ok it has been 4 years now since I got the calipers replaced on the rear. Ever since then they have kept going bad. Well last week I got another one put on. The 4th one in as many years. Well everything was cool until tonight when I got back in to town and opened the garage door to find that a stream of brake fluid had formed from where the new caliper was to about 8ft from there. Well the rear resivoir was empty in the master cylinder so I filled it up started the car and the BRAKE light on the dash lit for a while and as I pumped the pedal(expecting fluid to squirt out) then went off. Now its not leaking and I only have one day in town. I know something is broken but I dont know if I can prove it. I mean I cant drive the car if I can't trust the brakes. Has anyone had similar experiences with 4 wheel disc? Mine is an 86 with a 9 bolt.
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank, bearings, rings, and magnafluxed rods. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,SVO 24# injectors,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Reply 0
Jul 22, 2000 | 04:05 AM
Did u forget to put the washer that goes between the caliper and the fitting on the brake hose ? Did you put it in backwards ? Dunno.. something to think about. Where exactly is it leaking from ?? Try and find out
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Reply 0
Jul 23, 2000 | 01:48 AM
whoops
[This message has been edited by Ratnose86SC (edited July 22, 2000).]
Reply 0
Jul 23, 2000 | 09:31 PM
This is the 6th caliper in 4 years and the last one got like 30 miles on it. It is leaking form where the Emergency brke cable goes into the caliper. I dodn't pu it on 4 years ago I had a local garage that a friend of mines dad ownes do it and I t is always under warranty when I take it back with a problem so it doesn't cost me anything. SO I watched Josh put it on there and it seems like evrerything goes back right. I dunno. Still I as anyone have similar problems. Oh and it did start leaking again after it stoped.
On a good note I got my strut towerr brace on and I love it.
Reply 0
Subscribe
