Headlight Switch Problem
Old Nov 12, 2012 | 04:44 PM
hale89's Avatar
Car: 91 Camaro RS
Engine: 305 V8
I am having a problem with my lights. Here's what happened...
I was going to pop the hood (all lights working at this point) and when i pulled the lever the two wires coming from the headlight switch to what i believe is the switch for the dome light (side of the door) got caught and pulled loose. The previous owner didn't take very good care of this car, so instead of just the wires coming loose, the entire connection came off, and I don't know if I will be able to replace/fix it. But anyway, now the headlights, tail lights, dome light, and horn will not work. Is there a fuse/relay i could have blown if those exposed wires hit something? Or could that have damaged the switch itself? Or any other ideas? I am stuck!
Old Nov 15, 2012 | 04:36 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Headlight Switch Problem
You probably pulled the wires loose inside the car. You'll need to take the panels off and trace the wires to see where they go.
Old Nov 15, 2012 | 02:01 PM
hale89's Avatar
Car: 91 Camaro RS
Engine: 305 V8
Found the problem! It was where the fusible links where cut out, the wires had melted the tape around them and was hitting metal. Thanks for the reply.
Old Nov 16, 2012 | 06:02 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
It's your car, but I think you should replace the link properly. You got lucky, you caused a short and it gave out where the link had been improperly spliced (which is no-no). It could just as easily melted anywhere along the whole length of the wiring and destroyed a large part of your harness or set the car on fire. Fusible links are like fuses that shouldn't blow, when they do blow they must be replaced, not bypassed after the short that caused it to blow is fixed. I don't know if you've ever seen a car burn down, but I'm guessing you don't want to with this car. Change the link and never twist wires together to make a connection, either solder or crimp.
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
tnrednneck
Aug 13, 2015 08:57 AM
