timing gear
Old Apr 14, 2003 | 07:37 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
timing gear
after my cam swap my car only runs right with the distributer turned as advanced as it will go.....the only thing i can think of is could this be from only installing a new cam gear and reusing the old crank gear?
Old Apr 14, 2003 | 07:43 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
A common misconception is when the dots are facing each other, #1 cyl is at TDC on the power stroke, but actually #6 cyl is at TDC on the power stroke. Is that what happened?
Old Apr 14, 2003 | 07:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Did you put on some kind of aftermarket timing cover?
Old Apr 14, 2003 | 07:50 PM
Car: 83 Camaro
Transmission: th350
original timing cover......i was just searching and found some people ran into problems with using different gears......ok i have my distributer tunbred so that the part where the coil comes out straight on it.,...instead of somehwere around horizontal.....is at a 45 degree angle or maybe slightly more counter clockwise turned
Old Apr 15, 2003 | 09:44 AM
Vader's Avatar
Did you happen to compare the dowel pin location on the replacement sprocket to the original? The dowel position should be the same in relation to the marker "dot". If you still have the original (removed) sprocket, you can visit your supplier and compare it to another replacement instead of tearing the cover off again.
eightsixseven
Dec 16, 2024 01:50 PM
junkcltr
Aug 2, 2019 11:12 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
86White_T/A305
Aug 17, 2015 12:16 AM
