More Torsen questions
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I searched through the archives and couldn't find the answers. I know many of you have converted to the SLP Torsen carrier so you might be able to answer a question. I want the HD unit myself.
I know the Torsen doesn't use a cross pin. How are the c-clips retained on the axle without one?
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
Best ET on a time slip: 11.857
Best corrected ET: 11.233
Best MPH on a time slip: 117.87
Best corrected MPH: 125.46
Best 60 foot: 1.662
Racing @ 3500 feet plus density altitude!
Member of the Calgary Drag Racing Association
Best 60 foot: 1.662
I have the HD Torsen, it uses a block instead of a pin. Same idea, it has a bolt that locates it in the center of the carrier. This has the effect of holding the axles in place such that the c-clips can't fall out.
-Kevin
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
-Kevin
1982 Z-28
Orr89RocZ
Oct 7, 2015 12:47 PM
