single side belt pic(no alt or a/c)
Old Apr 15, 2003 | 08:42 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Click here for pics and info
Old Apr 15, 2003 | 11:47 PM
burnoutrpm's Avatar
howd you make the bracket and how can i make one?????
thanks
Old Apr 15, 2003 | 11:57 PM
Aaron91RS's Avatar
Car: RS
You mean the one from the header to the alt? Probably you mean a tensioner one. There is no tensioner the belt is the exact size.
Old Apr 16, 2003 | 01:29 AM
rezinn's Avatar
Belts stretch. V-belt setups had grooves to allow for this. Tensioners allow for it. Your setup doesn't. I tried the same thing and it ate belts. Using too small of a belt strains it because it's too tight. Using the right size causes the tension to be incorrect once it stretches. Either way, the belts won't last long. I hope you have better luck than I had, or maybe better belts?
1992 Trans Am
May 10, 2023 07:19 PM
mustangdmurder
Aug 21, 2015 07:17 PM
BikeFarm
Aug 11, 2015 11:35 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
