Puff of Smoke\Steam comign out of breather,,Is This BAD???
Old Jul 24, 2000 | 10:07 AM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
OK, I have an open element and I put a Chrome breather in the valve cover. When I open the hood i can see the condensation uild up on the chrome valve covers like it is pufing it out. It's nota constant stream, but it a consistent puff. ANyone have any idea what this is caused from? It really annoying and making my chrome look like Crapola! I'm not sure what else to tell yuou about it. I've never encountered this. Ask if you need more info.
Thanks,
Lars
'92 RS 305 TBI
K&N Open Element
Ultimate TBI mod's (thanks Pablo)
Cam[.442"/.465" x 218*/224* @ .050", 10:1 Hypereutectic Pistons
Performer Manifold
Shift Kit, Corvette servo,
and 2800 Stall Trans Specialties Converter,
Gutted Cat, IAT Resistor
MSD Blaster Coil, Accel Cap and Rotor
Old Jul 24, 2000 | 10:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it's an actual breather, with holes and the metal mesh and all that, then it's not just condensation, it's oil vapor and everything else out of the crankcase. You need to get rid of it and hook the stock type of closed system back up, otherwise you will always have that crap everywhere and your motor will smell like old cars always do.
Nearly all of the typical open-element bases have the means to hook up a breather hose like the factory system. Get the right fitting for yours, or at least one that you can make fit, and then go to the parts store and get a piece of moded heater hose that will fit as neatly as possible. That's one piece of clutter under there that you really shouldn't try to do without.
db057
Apr 28, 2019 07:45 AM
69GTOby
Apr 18, 2016 02:34 PM
92-Formula
Dec 12, 2015 10:34 PM
Stryker412
Sep 20, 2015 06:59 PM
Accerrito22
Sep 5, 2015 09:34 PM
