NEED HELP QUICK....Can I use power brakes with Edelbrock manifold and Holley carb???
Old Apr 16, 2003 | 05:19 PM
CamaroX84's Avatar
Here is the setup:
-Edelbrock Performer RPM Airgap manifold
-Holley 700 CFM double pumper carb
How am I supposed to hook up my power brakes? The only port I see on the manifold is near the back of the carb, right underneath it. There is no way of getting a vacuum fitting in there. Is there anything I can do without running a spacer? ANY help would be greatly appreciated. I really want to get my car going. Thanks in advance.
Old Apr 16, 2003 | 06:06 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Run the brake booster line into a pipe fitting in an intake runner of the manifold.
Old Apr 16, 2003 | 07:20 PM
CamaroX84's Avatar
The only hole in any of the runners is the one I described. I talked to Edelbrock, and they said to get the low profile 90 degree fitting from them, but when I look at it, there is barely any clearance at all under the carb. Thanks.
Old Apr 16, 2003 | 09:09 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
carb spacer
Old Apr 16, 2003 | 09:23 PM
CamaroX84's Avatar
I seem to remember reading an article in Super Chevy that showed a decrease in power when a carb spacer is used with the performer RPM airgap. Anyone know anything about this?? Thanks again.
Old Apr 16, 2003 | 10:58 PM
CamaroX84's Avatar
Well, I'm officially an idiot. I didn't realize that the carb itself had a vacuum port on it. It's on the secondary side right under the float bowl. It was covered by a black rubber cap. Thanks for all the replies! I really didn't want to go buy a spacer.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Sep 17, 2020 08:26 AM
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Aug 17, 2015 02:00 PM
stalkier
Aug 13, 2015 12:59 PM
