a/c belt vibration
a/c belt vibration
I am sick and tired of the belt vibrating at idle when the compressor is on. I have tried longer belts, shorter belts and every tension possible and still cannot stop it. does anybody have a fix or has anyone swapped the alt and comressor to opposite sides like post 86 cars? if noone has a fix than does someone have access to a machine shop or garage where an idler pully can be fabricated and installed between the water pump and compressor?
