Questions With Pictures To Go Along
Old Apr 18, 2003 | 05:42 PM
blue86z28's Avatar
READ--Give me a minute to fix this--geocities is being a bitch with linking of files and saying their gonna shut my site down--i gotta find another host...
Im Not Trying To Put Down This Board But The Pictures Will Only Show Sometimes So I Hope This Can Be Fixed--The Pictures ARE There--I Included The Links So You Can Look At Them
OK--The Temperature Of The Engine Looks To Low--Is It?
I Have A Brand New 195 Degree Thermostat And The Fan Comes On At This Temp--Seems Like It Wants To Run Too Cool...
http://www.geocities.com/red88z24/mtemp.JPG
The Oil Pressure Also Looks To Low--Is It?
I Changed The Oil And Filter 3 Weeks Ago...
http://www.geocities.com/red88z24/moil.JPG
Here Is A Picture Of A Green Single Wire That I Have Never Found What Is Goes Too--Where Does It Go?
http://www.geocities.com/red88z24/mwire.JPG
And Here Is A Picture Of A VERY Beautiful Car--(the engine could use some polishing up)
http://www.geocities.com/red88z24/mcar.JPG
http://www.geocities.com/red88z24/mmotor.JPG
Thanks Very Much!
Old Apr 19, 2003 | 01:53 PM
Vader's Avatar
Yes, trying to link files from Geo****ies is a be-atch. Does the word "suck" come to mind?
Anyway, what is the fan turn-on temperature, according to the dash gauge? And what is the indicated oil pressure at warm idle?
You should be aware that the dash gauges aren't all that accurate, and that the oil pressure and temperature sensors for the gauges do get out of calibration frequently. If you're concerned about oil pressure, the first thing you should do is install a mechanical test gauge in a convenient port, like the gallery plug at the front of the block above the water pump - your '88 should have the 1/8" pipe plug. Compare that to the dash gauge to get a reality check.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
PestilenceIV
Aug 20, 2015 02:33 AM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
