code 22 TPS low voltage...is it DOA?
Old Jul 23, 2000 | 02:47 PM
james_fearn's Avatar
My car is idling eratic and surging when cruising. I also get code 22 (low voltage). Is the TPS dead or dying? I believe it can cause the surging but also the bad idle??
James
1985 Z-28 305 TPI
215,000 mi. Original Eng.
Old Jul 23, 2000 | 05:26 PM
rondubbs's Avatar
make sure the voltage is @.54 volts dc at idle and near 5 vdc at wot. use a digital voltage meter. if you cant get a reading your tps is probably bad.
Old Jul 25, 2000 | 06:44 AM
Scott 87 IROC-Z's Avatar
Car: 87 IROC-Z28
Engine: 377ci, Brodix Heads, Solid Roller c
Transmission: 700-R4 w/ Yank ST3500 Converter
What if it is .54 at idle but only gets up to 4 at WOT? Should it be replaced?
87 IROC-Z 305 TPI
MSD 6AL & Blaster II Coil, Richmond 3.73, K&N Filters, TPIS Airfoil, TPIS AFPR, Custom Cold Air, KYB Shocks & Struts, Ported Plenum Runners and Manifold, Comp. Eng Subframe Connectors, SLP Headers, Borla 3", Hi-flo cat, TH700-R4 with TCI Pro Super Kit and 2000 rpm stall converter
www.acsu.buffalo.edu/~ermer
LT1 for spring 2001??
Cornholio7979
Sep 20, 2018 02:31 AM
GTAman
Sep 21, 2015 09:57 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
