Knock sensor???
Old Apr 20, 2003 | 12:29 AM
Metallica383's Avatar
Knock sensor???
What all does the knock sensor do and how do I know if it is bad?
I was told that it advanced the timing. I was wondering could this be a cause of lack of power.
Old Apr 20, 2003 | 02:33 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Re: Knock sensor???
The knock sensor detects engine vibration, or knock, and adjusts the timing to compensate for it. Do NOT run your engine without a knock sensor. Without it, you run the risk of engine detonation. I highly, highly doubt the knock sensor could, or would cause a lack of power. As far as checking one, I'm not too sure if there's an easy way to do so, but they are about $30 from a local auto zone, so they aren't too expensive to replace. Do you think you have a bad one?
Edit: I saw your other post on the manifolds... throw a timing light on your motor and check it, it sounds to me like you have too much timing advance.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
