fuel tank drop
Old Apr 20, 2003 | 08:11 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
fuel tank drop
how hard is it to drop the fuel tank? i have a hole in the top and i need to plug it up.
Old Apr 20, 2003 | 09:08 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Its a real pita, first get a pair of saftey glasses. Siphon your gastank and leave the gas cap off. Then you have to jack the rear up, put 2 jack stands under the rear of the car, not under the rear end. Now you need to take out the bolts in the rear sway bar"panhard bar" where it attaches to the rear end. Next you'll have to remove the rear exhaust. Now you may or may not have to do this next step, I didnt when I put an new tank into my car. But you may have to drop the rear end to get easyier access to the tank. Remove the 2 tank straps and the wiring harness connector and then your ready to drop the tank
Old Apr 20, 2003 | 10:03 PM
82Z28NAZ
Guest
Posts: n/a
I see you have a 200 4R in your car too. How did you get the torque arm to mount?
Old Apr 21, 2003 | 10:35 AM
TheViper's Avatar
Car: '84 Z28
for the trq arm i had a peice of steel bent at a 90* angle and drilled it out where i needed the trq arm to go. i also needed the peice of steel because the mouting holes didn't line up.
Old Apr 21, 2003 | 01:23 PM
82Z28NAZ
Guest
Posts: n/a
just bolted the torque arm to the piece of steel?
Grant2k
Jul 10, 2018 04:01 PM
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Kaweh
Aug 9, 2015 02:54 PM
