Pinion angle waaay off now, but why??!
Old Jul 24, 2000 | 07:39 PM
355 IROC-Z's Avatar
ok, i just put everything back together today since i finally found some time off. well, i had the torque arm off and put in a new clutch fork and removed my flywheel shim and did other minor maintainance.
anyways, i put everything back together and the pinion angle is way off now. the rear end looks shifted back and the front of the rear end is way up in the car. i didn't really change anything and can't figure out why nothing lines up. the torque arm looked alright, too. any ideas would be appreciated. my enthusiasm for my car is quickly goin away here
87 iroc-z 355 TPI 5 spd. 51006 SLP cam adv. 4* (106.5* centerline)
hypertech stage II chip/ 160* stat./ Airfoil, accel AFPR
3.45 rear (stock)
Flowmaster, K&N w/ hacked airbox
14.38@100mph 2.2 60'
removed MAF screens
Old Jul 24, 2000 | 07:43 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Look up by the tranny on the driverside and see if the TA came out of it's mount....the TA is probably up against the tranny tunnel
Old Jul 24, 2000 | 07:51 PM
355 IROC-Z's Avatar
nope, i already check that before i wrote this. i am too familiar with the sound it makes when it comes up and hits the floor board. i do have one of those poly torque arm mounts and have had trouble with it ever since. that is one reason i had it apart, but i haven't had a problem with the pinion angle. good thing is that i have no more shifting problems
Old Jul 24, 2000 | 09:14 PM
mikeage2's Avatar
well,if you had it off,and had weight off the rear end,its possible that a spring has come out of its seat....check that...ive also seen people put in the crossmsmber upside down+backwards/////im sure you are a bit smarter that that,but you never know
83 berlinetta:well,now its a 87 z-28,but insurance dosent have to know that.
350 .040 over.line bored.deck milled.020
trw forged pistons with summit stage 2 rods
190 something intake valves,old vette intake with 750 holley(junk)
ase certified for two years,learned alot though
working on freakin neons ,cirruses,tauruses,and intrepids all day makes me drink too much
Old Jul 24, 2000 | 09:39 PM
355 IROC-Z's Avatar
mike, yes that makes total sense to me now. i do recall looking at the rear end here last week and thinking the rear end was about off the springs. i will definately look at that tomorrow. well, it is good to make sure that i covered the basics but i have had my car apart more then i have had it together. thank you for your help.
Old Jul 25, 2000 | 12:23 PM
355 IROC-Z's Avatar
just took a look at my springs to make sure they were in there proper position. it doesn't appear that they are problem, but you can definately tell that the rear end needs to be rolled forward. the bottom of the springs aren't sitting flat on the plates. anymore help would be appreciated. i will put the car back up in the air tonight and look at it closer.
jbates346
Oct 21, 2015 01:50 PM
gord327
Oct 3, 2015 01:25 PM
gord327
Sep 29, 2015 10:18 PM
mfp189
Sep 27, 2015 09:25 AM
dimented24x7
Sep 17, 2015 06:58 AM
