power steering
Old Jul 25, 2000 | 12:25 PM
83berlinetta's Avatar
power steering
i just dropped a '79 350 into a 84 firebird replacing the 173. my problem is that the belt for the power steering pump is slipping only when the steering wheel is turned. when this happens it appears that the pump is moving at a much slower speed than the belt causing a screeching sound. the power steering still works, fluid levels seem fine, the belt is tight. is the power steering pump bad? could there be air in the system? would it even matter if there was air?
Old Jul 25, 2000 | 01:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The belt is loose. Tighten it.
Squeaky8791
Feb 5, 2020 08:29 PM
Vintageracer
Jan 10, 2020 05:33 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
deracer
Apr 11, 2016 12:04 AM
