Tranny/Clutch problem.
Old Jul 25, 2000 | 11:53 AM
92TAConv's Avatar
My cousin's 89 Chevy pickup makes a rattle when its setting at an idle. When he pushes the clutch in, it stops rattling. Let off again, rattle.
I've heard this called a bad carrier bearing. Where is the carrier bearing located and is this my problem?
92 Convertible Trans Am: Mostly stock, L98 long block, ported heads, SLP Headers, Hypertech, K&N.
84 Camaro: 454/TH400 in progress.
Old Jul 25, 2000 | 12:28 PM
MrJ's Avatar
MrJ
It's called a throwout bearing, and it's not too hard to replace, but the tranny has to come out of the car.
Old Jul 25, 2000 | 12:54 PM
92TAConv's Avatar
I suspected the throwout bearing. We are going to pull the tranny this weekend and see exactly what the problem is.
Is it obvious that the bearing is bad when you see it, or can they start to rattle before they are visibly bad?
Do some people refer to the throwout bearing as a carrier bearing?
What makes one go out?
Thanks,
Nick
Old Jul 25, 2000 | 02:00 PM
MrJ's Avatar
MrJ
One big thing that kills them is keeping the clutch depressed at every stoplight, rather than shifting into neutral and letting the clutch out. It puts a lot of stress on the bearing and leads to premature failure.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
HoosierinWA
Oct 7, 2015 10:15 AM
mcbitchman
Sep 29, 2015 12:32 AM
383cam
Sep 9, 2015 06:01 AM
