Rear-end can't handle awesome power of LG-4
Old Jul 22, 2000 | 08:02 AM
MikeDwhoROCZImports's Avatar
Apparently not, because I busted a tooth off my spindel.
I'm flippin through summit thinking about getting some richmond gears (any other reccomendations?) but wondering what diameter pinion and ring gear our cars have?
Right now I have a 5 spd and a 3.27 but I think I'm gonna switch over to a 3.73 or a 3.90....what do you guy's suggest?
"Doin 120 Mowin' over mail boxes, radar detector, to show me where the cops is."
"Ain't no such thing as a front wheel drive sports car...I can smoke the tires in my 1985 Accord with 87hp (factory rated)."
1987 IROC-Z28 Camaro
-ADS Super Chip-Replaced all fluids with Red Line Racing Synthetic fluids-Griffen "Nascar" Aluminum Racing Radiator-Good Year Super Hi-Miler Cooling Hoses-160 Degree Thermostat-Jet Fan Switch- Center Force Dual Friction Clutch-Hays Flywheel-New Alternator-Polyurethane transmission mount-Doors sound insulated with Dynomat Super-Replaced Ratted Hoodliner with new one from GM-Accel 300+ Spark Plug Race Wire with Pro-Sleeve -Bosc Platinum +4 Spark Plugs-305 H.O. Dual snorkel intake-Four Dunlop SP Sport 9000 tires (245/50ZR16)-3.27 Gear Posi Rear End off 89' Trans-Am (Sandblasted and Painted Black with Yellow rear end cover)-Rear Disc Brakes (11.65 inch rotors with PBR Aluminum Calipers off 89' Trans Am)-Polyurethane bushings on rear sway bar-Catco free flowing high performance catalytic converter-Hooker Super Competition 3" Mandrel Bent Cat back exhaust-Replaced cardboard headliner with a waterproofed fiber glass headliner....much more comin' soon. =)
Old Jul 22, 2000 | 08:40 AM
Dr. Pepper's Avatar
What year is your car? 3.27 sounds like a Borg Warner rear end. In which case gears will run you about $400 and are of limited availability. If it is anything else it is a 7.5" or 7.625" axle. The gears are interchangable, GM just used slightly different sizes in different years. First count the number of pan bolts in your axle, 10 is the 7.5"/7.625", 9 is the Borg Warner.
Old Jul 22, 2000 | 03:40 PM
Hurtin4Hp's Avatar
Car: Transformed 86 Coupe
Engine: 400 sbc
If it is a 10 bolt rear, most places sell a different gearset depending on whether it is a 7.5 or 7.625". Being that your current gearset is a 3.27, you would more than likely have a 7.5".
Old Jul 22, 2000 | 06:47 PM
Whoops..I forgot to mention I don't have the original rear-end in the car. It's a Borg-Warner 3.27 out of an 89 TA.
Old Jul 24, 2000 | 02:36 PM
Anyone.........anyone?
Old Jul 24, 2000 | 02:53 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
You won't find gears for the 9-bolt in the Summit book. I'd go for the 3.70, seeing that that's the only 'performance' ratio offered. Gears cost $299 from either DTS or Reider Racing. Don't know if Summit can get them or not.
Old Jul 25, 2000 | 03:14 PM
Thanks.....I went looking around to see what I could get. The best I could do so far was 3.70's and they'd cost me $319...........damn that sucks. Even worse, I went to my local chevy dealer just for the help of it......they priced a stock 3.23 at over $600!!!!!!!!
I hate you Borg-Warner rear axel!!!!!!
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
sailtexas186548
Aug 24, 2015 10:11 PM
sreZ28
Aug 14, 2015 07:48 PM
