i need intake manifold info!!
Car: 85 trans am
Engine: 79 4 bolt 350
i am going to buy an intake manifold in a few days and im wondering what is everything you need to put in a new one, and what does it do to the throttle and tv cable locations? i have a 600 cfm edelbrock carb, and flowtech headers on a 1979 chevy 350, what kind of improvements will i get? right now i have a 305 intake manifold on it. and last question, would you recomend weind or edelbrock? thanks
Transmission: 4L80E/4L80E
Gains? Really depends upon your other mods, like exhaust and cam.
If those are stock, gains will be next to nothing. I put the GMPP manifold on when the LG4 was basically stock - only put it on because I had to pull the stock manifold to fix a coolant leak - only mods at the time were open element air cleaner and stock TPI cat-back. I gained .05 sec for best time in the quarter (my times would vary more than .05 sec in a given night, typically).
After the mods, I didn't compare to a stock manifold, but when the rest is improved, the improvement of an aftermarket manifold will increase.
I'd recommend the Weiand Action + or GMPP intake.
ambainb
Apr 25, 2016 09:21 PM
