Need help quick!!! Gott a get this car home.
Old Apr 21, 2003 | 10:35 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
My friend says I can have a 92 ford tempo, just gotta come and get it outta his driveway. THink the starter is bad. When you try to crank it it makes 1 single click. I had him crank it for me while I listened, and it sounds like the sylenoid and the starter make the click. I tried jumping the sylenoid with a hot wire from the battery, and still no luck. SO that should rule out the neutral safety switch and the sylenoid right??? Does this just sound like the starter is locked or what. Any help would be appreciated.
Old Apr 22, 2003 | 04:10 AM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
It certainly sounds that way, unless the battery is totally flat.
Try having him crank the engine while you give the starter a knock with a hammer. That will free it up in most cases.
Old Apr 22, 2003 | 07:33 AM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Well, like I said, I tried jumping it. Even if the battery was totally flat it should have started it. I am gonna go try to tap the starter with a hammer today, see what happens. You are like the 5th person I have heard that from, I just didn't have the time to go back and pick up the car yesterday. I really hope that works.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
