piston rings alignment ?
Old Apr 23, 2003 | 06:36 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
hi guys.
please, i need some of your expertise concerning piston rings alignment.
in every overhaul manual, is indicated via figures, the positioning of the rings, see: A, B and C, no problem with that, but actually i'm itching to align them 180 degrees opposite, for example, if upper is fwd, second will be facing back, and so, sure keeping the same order for everyone, but before i do it, i'd like to ask your oppinion on the matter, i know the recomended positioning is to prevent exessive blow-by, but to me it looks even better 180 degrees appart, wouldnt you say so?
thank you gentlemen. :hail:
Fernando.
Old Apr 23, 2003 | 07:38 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They actually rotate around the piston as it goes up and down. That's why you want the cross-hatch pattern on the cyl walls.
But if any one of the ring ends lines up with any other, they will tend to develop deeper wear at some point around the cyl because of that, and eventually they'll hang up in the wear and stop rotating, and when they don't rotate, they score the cyl vertically which is what causes excessive blow-by and oil consumption.
So for max possible engine life, don't line any of them up with any others.
Old Apr 23, 2003 | 07:42 PM
Damon's Avatar
Not that it makes huge difference where you start them (since they move) but I've always followed 2 simple rules:
1. Don't line up any of the gaps.
2. Don't put any of the gaps on the thrust side of the piston.
Old Apr 24, 2003 | 05:46 AM
ede's Avatar
ede
some of my manuals show where to position each ring, not sure it really matter as long as the gaps don't line up like rb said. if i have a manual that shows where to position the rings i do "just in case".
Old Apr 24, 2003 | 04:38 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
so as long as they are appart, it doesnt matter if they are 180 degrees opposite? i'm thinking about for example, the upper one towards the front of the engine and the second towards the back, i think it will be harder for them to align.
another question, the trust side is it parallel to the crank shaft or transversal to it?
thanks again guys.
Fernando.
Old Apr 24, 2003 | 07:35 PM
ede's Avatar
ede
front of engine would be 9 o clock, lifter valley 12 o clock
oil ring spacer gap between 11 and 1
oil ring rail 7
2nd ring at 6
top ring at 12
Old Apr 24, 2003 | 07:52 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
thanks ede, you're the man. :hail:
Fernando.
Ed1LE
Sep 30, 2018 09:14 AM
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
