Just ordered my 1.6 rockers. I KNOW SOMEONE HAS THESE THINGS!!!
Old Jul 25, 2000 | 11:45 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
I'm getting them for my 350. Its basicly a TPI motor with a full exhaust but without the TPI. I run a carb, upgraded intake, adn a few bolt ons. How are these 1.6 rockers going to respond? Should I expect 5 hp?
1986 CAMARO Z28 -> 89' vette 350 block, Holley 650 DP, Weiand intake, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear, 90% Centerforce clutch, 3.23 posi, reinforced LCA's, Subframes connectors, front LCA poly bushings, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.37@ 105.7MPH Future mods-> 1.6 rockers, B&M shifter, homemade ram air.
Old Jul 26, 2000 | 12:46 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Better get your butt-dyno calibrated, otherwise you'll get false readings (read as in none). But at the track you should see a tiny amount difference. Seriously, yes average HP increase is 5hp.
George P. Lara
1984 Z28 High Output
Proud Member of SCFB
V6 T5 For Sale
[This message has been edited by MRZ28HO (edited July 25, 2000).]
Old Jul 26, 2000 | 12:47 AM
BOWTIROC's Avatar
From: Coulterville, IL...Currently on Beale AFB, CA
You should see a decent power gain if you are still running the stock cam, they need all the help they can get....I have a Comp cam for sale that would work great in there.
midge54
Dec 27, 2019 04:14 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
LT1Formula
Aug 20, 2015 09:36 PM
Bob88GTA
Aug 18, 2015 03:31 PM
milk
Aug 10, 2015 06:26 PM
