setting up my distributor....
Old Apr 23, 2003 | 07:54 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
well i made an attempt to do it tonite...........didnt work
i put my finger over the #1 spark plug hole and had my helper bump the engine over
i thought i felt the air push my finger off and the white mark on the balancer was facing upwards when you look through the water pump (looked like it was in the middle of the timing pointer)
so one of two things could have possibly happened
it wasnt on TDC on #1 but rather TDC on #2 (which is fired right before #1) because now that i think about it, the marker on the balancer was a little counterclockwise of the timing pointer
OR
i thought i felt the compression push my finger off and it really didnt, thus i was on TDC #6
i am pretty sure i had spark, because when i turned the key i some (very little) smoke coming out of the carb (seems like i had spark, but not at the correct time)
can i rotate the engine by hand a stick a screw driver in the #1 spark plug hole? because my first method (of sticking my finger over the plug hole) didnt work out so hot
also, i dont want to remove the valve cover because thats a project within itself (previous owner stripped out all 4 torx bolts on both valve covers )
also, the engine sat almost exactly one year without being started..............will there be oil pressure when i start her up, OR do i need to prime the pump
(like an idiot i did not drain the oil, nor the coolant)
thanx for your help
Old Apr 23, 2003 | 08:20 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I would definitely prime the oil pump first. You would for sure know if it pushed air out the hole. Did you get someone to turn it over with the key? You could just turn it over by hand and line up the timing mark on the 0* mark. Then you would have a 50/50 chance of having it right. If it's 180* out then just pull it out and turn the engine over 360* and you'll have it right for sure.
Old Apr 24, 2003 | 07:59 PM
cool, i got it running
didnt prime the oil pump........ede says its useless........my pressure gauges reads fine
got dark out tonight, so i am going to set the timing tomorow night
thanx!
Old Apr 24, 2003 | 09:37 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
thanx!
Glad you got it going. Hey, what's with the 700r4 comment in your sig? I use one and will be in the 11's in the next couple of weeks. The guy that built it ran a 6.89 in the 1/8 mile with one built just like mine. 6.89 converts to about a 10.75 in the 1/4. I guess what you mean is "Friends don't let friends use "STOCK" 700r4's."
Old Apr 24, 2003 | 09:52 PM
stock pretty much
i just hear alot of bad things about them
i took apart and looked at the guts of the one that was in my Z28
not pretty
i just dont like them, lets leave it at that (i can really go into it, but i dont feel like writing a book)
Old Apr 24, 2003 | 09:56 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
stock pretty much
not pretty
That's cool!
82tabird
Dec 21, 2015 10:22 PM
lt1z350
Sep 29, 2015 01:50 PM
hydrolic144
Aug 29, 2015 04:14 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
mustangdmurder
Aug 21, 2015 07:17 PM
