Push Rods
Push Rods
does an '89 roller 305 come with Self aligning rockers ?? if so, are the stock pushrods hardened ?? also,,... do roller rockers make that much of a difference over roller tip, and stamped for that matter... what sort of difference??
Car: 82 Z-28
Engine: 383 TPI
I believe the rockers are self aligning. To be sure pull a valve cover and check them.
If you do have self aligning rockers, I doubt if the stock pushrods are hardened.
Full roller rockers have a lot less friction. Generate a lot less heat and provide more accurate valve actuation. They will drop oil temp 30 degs or so. Stamped rockers flex and the ratio can vary a suprising amount between individual rockers.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Anyone have any hard proof of that? That sounds like a lot. I've also heard things like "Roller rockers are good for 20hp! over your stamped roller-tip".. Any hard proof of that either?
-- Joe
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
-- Joe
-- Joe
"Rubber rockers" as RB is known to call them
Car: 82 Z-28
Engine: 383 TPI
In John Lingenfelters book "on modifying small-block chevy engines" pg. 114 it says a 10-15 deg drop in oil temp on a stock eng.
I read somewhere else (don't remember where), that if significantly stronger valve springs are used (i.e. 380-420 lbs open), the oil temp reduction is around 30 degs.
I can't prove the second part, but it sounds reasonable.
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
