Superchip for LG4 4bbl?
Old Jul 26, 2000 | 05:02 AM
radiaki's Avatar
is there a superchip i can get for my 1986 trans am with a 305 4bbl LG4???
Old Jul 26, 2000 | 06:13 AM
kissfreak2's Avatar
Dude, you can't get a chip for a carbed car.
Old Jul 26, 2000 | 06:25 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Yes! any of the chip companys offer chips for carbed cars.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Moroso Blue max wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Jul 26, 2000 | 03:09 PM
radiaki's Avatar
its a computer controlled carb, so the computer must have a chip? I saw someones car on here a couple weeks ago and it said it had a q-jet with a hypertech superchip.. what was that about??
Old Jul 26, 2000 | 03:52 PM
Blade's Avatar
It's better to shut up if you don't know what you're talking about
Yes, they make chips for your car. Honestly though, it wont help your peformance much. Maybe 5 HP at the most
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Jul 26, 2000 | 05:29 PM
daniel dekay's Avatar
alot of companies make a chip for the carb'd computer. i had an lg4 and i bought a jet chip. hypertech makes one too. about the HP, i wouldnt know cuz i decided to 86 the lg4 in favor of a 350.
86 camaro cpe(dont laugh)has 92z28 body kit with GTS covers and a killer stereo. 2 amps, 8 speakers, disc changer, custom install with subs coming by the end of the summer. sawpped (or in the process of) 305lg4 for brand new 350. TES headers, flowmaster cat back, performer manifold, TCI converter, jet chip, kn with dual snorkel cleaner. and she still passed the sniffer!
"Cal Poly SLO is the shi#"
dusterbd
Sep 29, 2015 08:40 AM
podiatra
Aug 31, 2015 09:53 AM
ambainb
Aug 29, 2015 12:43 AM
86IROC112
Aug 17, 2015 02:00 PM
Dquickshift
Aug 12, 2015 06:21 PM
