lg4 fuel pump installation help PLEASE!!!!!!!!
Old Jul 26, 2000 | 07:30 PM
silvermelon's Avatar
right now the car hasno fuel pump. the old one came off easy, and the new one refuses to go on. if we get one bolt going, we cant get the other one on because it wont line up. is there any special way to get it on, because its not working. how do i get this thing on??????????????????????
Old Jul 26, 2000 | 08:26 PM
MeanYellowZ's Avatar
crank the motor over a little bit, it sounds liek the fuel pump pushrod is in the outer position right now, turn the motor so it gets more near the bottom of the eccentric. Also, make sure to push the rod up in its bore and get the fuel pump arm under the rod. Its a slightly complicated process which requires patience and skill...oh wait, I can do it...
1986 yellow Z
pics of my Z:
Camaro1 Camaro2 Engine
More at: My Directory
Email: MeanYellowZ@hotmail.com Aol/IM: RCY1980
Owner of the Camaro 9 out of 10 Thirdgenners approve of, part of the non-existent Iowa crew.
Old Jul 26, 2000 | 08:59 PM
hey thanks, i see that but how do you get and keep the rod up? . nice car man!
[This message has been edited by silvermelon (edited July 26, 2000).]
Old Jul 26, 2000 | 09:32 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Just in front of the pump mounting surface, on the front of the block, is a 3/8" bolt....take it out and temporarily install a longer bolt and just snug it up enough to hold the pushrod in place...DO NOT forget to reinstall the original bolt or you will have a massive oil leak.
Pete
Pete's Place
Now at HiOutput.com
83 SC...LG4/5-speed from an 84 Z28, 3.42 one-tire-fryer, T-tops, PW, PH, gray interior from an 86 Firebird SE, seats from an 89 Formula, Wheels from an 83 Z28, springs and rear bar from an 84 Z28, WS6 front bar, Hedman Hedders and y-pipe, Dynomax cat-back, .420" lift cam, Accel HEI Supercoil and foam air filter, custom air induction through Z28 hood.....best ET (so far on paper) is 15.19@94.25
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
