Ticking noise
Old Apr 26, 2003 | 10:50 PM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
Ticking noise
Every time I turn my key to the position where the power comes on but car not started yet, theres a ticking noise that I can hear under the hood if I just leave the key in the ignition. Please help.
Old Apr 26, 2003 | 11:46 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
It's probably your fuel pump priming. Although the pump itself doesn't (or shouldn't) produce any "ticking" sounds, you might notice a single "tick" when the pump cuts out, which should be a few seconds after you have the key in the ignition position. This is what it's supposed to do...
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Sounds like you have a CC carb under your hood! That's the mixture control solenoid. After a few minutes, it should stop, until you start the engine. The mixture control solenoid controls the air/fuel ratio (well, it tries anyway) at idle and part throttle.
What year car, and what engine is in it?
Old Apr 27, 2003 | 07:20 AM
Vader's Avatar
It could also be the idle air control on an EFI system, or possibly the FPR.
Old Apr 27, 2003 | 08:53 AM
warrior_91's Avatar
Car: 86 T/A
INfo on my car
I have an 86 4 bbl carb, 305, 5.0 L, V-8
Old Apr 27, 2003 | 09:17 AM
JP84Z430HP's Avatar
Car: 84 Z28
Re: INfo on my car
Definately the M/C solenoid then. 100% normal!
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
