vortec versus trick flow
Old Apr 27, 2003 | 07:57 AM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
I have an earlier set of trick flow heads on my sbc and have been hearing alot of good things about the vortec heads. I am moving up to the stealth ram with about 10:1 compression, XR276 hydraulic roller cam and was wondering if you guys think I should ditch the trick flow and go with the vortec heads? Thanks.
Old Apr 27, 2003 | 08:41 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
No I'd keep the TF heads. Those are very good heads that flow better and I don't think you'd benefit from the vortecs. Besides all that, I don't think Holley makes a StealthRam that will bolt up to vortec heads.
Old Apr 27, 2003 | 11:32 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You could always have those heads CNC machined to flow like a bastard.
Old Apr 28, 2003 | 01:44 AM
Ian_F's Avatar
Car: 1996 Jeep Cherokee
Engine: 4.0
Transmission: 5 speed
Yeah, Trick Flow makes a nice head. I would stick with those and use the money you were going to use on the Vortec's and port the crap out of the TF's. Yeah and I dont think the stealth ram will bolt up to the Vortec's either.
Old Apr 28, 2003 | 09:15 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i'd also say stay with the trick flow's. the vortec heads aren't bad, after paying alot in machine work....
Old Apr 28, 2003 | 10:17 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I have no experience with either head, but by the time you buy the Vortecs, their intake, and machine the heads, because I think that cam is too large for the stock springs on the Vortecs, you could put a lot of work into the TFs for a lot cheaper.
Old Apr 28, 2003 | 10:18 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I had a set of TF 23's. I sold them cause they didn't flow all that well. If you are gonna keep them, do a little porting on intake and exhaust ports, but concentrate on the bowl job and valve angles, this is where the TF's will benefit the most.
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
dusterbd
Sep 29, 2015 08:40 AM
RS Reaper
Sep 27, 2015 07:04 PM
