4 bbl carb
Old Apr 27, 2003 | 09:05 AM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
4 bbl carb
I was wondering why every time I start my car, I have to pump the gas pedal to start it. I cant just go into my car and turn the key for it to start. I have to pump it. Why is that? 86 Trans am, 4bbl carb, 5.0 L, 305 ci.
Old Apr 27, 2003 | 09:53 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Depemds on how long the car sits between starting. Usually you can start it without pumping it after a couple hours. Check the check valve on the fuel filter to see if its there, most people like me remove them and have no problems some some people will have bleedback.
Old Apr 27, 2003 | 09:55 AM
Vader's Avatar
Your engine needs a little extra fuel to start. If the engine is cold, you also need to cycle the throttle once to set the thermostatic choke and high idle cam.
What you are describing sounds completely normal, and should be outlined as such in your owner's manual. If you had to HOLD the throttle open to start the engine, that would be a different issue and likely indicate a problem.
Old Apr 27, 2003 | 07:44 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Doesnt seem unusual... i usually have to pump it a few times if its sat for a day or more.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
dusterbd
Sep 29, 2015 08:40 AM
efiguy
Sep 27, 2015 01:30 PM
