Holy smokes !!!
Old Apr 27, 2003 | 09:24 AM
fakeyankee's Avatar
Car: 87 T/A
Engine: LM1 350
Transmission: 700 R4
Holy smokes !!!
My 87 T/A LG4 smokes a blueish color for about 2-3 min. after startup. Then I can't see smoke unless I rev it up a bit. The exhaust has an oily smell to it also. This is probly a lame question but; Does this sound like the heads need to be rebuilt, or the bottom end ??? What is the best way to tell ?? The motor still runs real strong and has lots of power. Could this be a bad timing issue ?? Please advise !! Is it time to put the ol 305 to rest and ressurect a 350 ??? Thanks
Fakeyankee.
Old Apr 27, 2003 | 09:27 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
you need new valve seals
Old Apr 27, 2003 | 09:34 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, valve guide seals, a universal issue with these motors as the factory builds them.
You can fix it with the motor still in the car. It's a cheap, easy, relatively permanent fix.
Old Apr 27, 2003 | 04:23 PM
mdr211's Avatar
Car: 86 camaro Z28
Engine: 305 carb
i need to change some valve seals on an 86 iroc tpi, does anyone know a good way to do it? ill check the tech articles out, but im a semi-rookie so any help would be great...
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
