Why does my oil come so far up the dipstick?
Old Apr 28, 2003 | 09:20 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Went out to check the oil in the IROC. Did the usual pull, wipe, insert and pull again. Only I had oil coming almost half way up the dipstick. Kinda makes it hard to get an accurate reading.
I know its not overfilled, I just changed it myself about a month ago. 5 quarts of 5w-30. The car had been siting almost 24 hours.
Pressure is good while driving.
Is something wrong? Should I change the oil again and use 10w-30? I only use the car in the summer so I'm not worried about the winter.
1986 IROC 5.0 TPI
bone stock
Old Apr 28, 2003 | 09:55 PM
R.O.B.'s Avatar
Double check the other side of the dipstick. I have this happen a lot on the trans stick, so try this. Otherwise, play it safe and change the oil and filter agian. 5w-30 vs. 10w-30 will make no difference.
Old Apr 28, 2003 | 10:00 PM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
Did the oil look OK? Sure you don't have coolant leaking in there?
Old Apr 28, 2003 | 10:02 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
I have the same problem...
It has to do with the way it gets dragged outa the tube...
like the other guy said, check the back and it should show you what the level really is...
Old Apr 29, 2003 | 11:48 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I'll try that. Any other input?
Old Apr 29, 2003 | 03:26 PM
Odyssey's Avatar
Your engine might have excessive blowby... OR one of your breathers is plugged or PCV valve might not work. Check that stuff too...
Old Apr 29, 2003 | 04:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You're not checking it while it's running, are you?
Old Apr 29, 2003 | 04:33 PM
zr1 32 16 405's Avatar
happens to me on alot of cars with bent dipsticks, even though it drags the oil you should be able to tell a flat line where it is somewhere on the stick and like everyone else says, if one side is dragged the other side should have more evidence
jrdturbo
Mar 31, 2016 02:58 PM
NZKnight
Oct 15, 2015 02:47 PM
skinny z
Oct 5, 2015 06:23 PM
Numbah-1
Oct 2, 2015 08:27 AM
